KB-17086: Message: “This resource is not available for this version of Elipse SCADA”.
Question:
When I click Databases via Organizer, the following message is displayed: “This resource is not available for this version of Elipse SCADA “. Why does this happen?
Solution:
This happens because the hardkey being used is an MMI Configurer, which doesn’t allow adding databases. To do so, you must update the hardkey to a PRO model.
Print Friendly, PDF & Email
Leave a Reply
