Question:
How can I copy a screen via E3Studio?
Solution:
To do so, there are two possibilities:
Via Domain mode:
Select the screen, press the CTRL key, drag it to Settings\Files\Name of the project to where you want to copy this screen, and then drop the mouse.
Via Explorer mode:
Select the screen, press the CTRL key, drag it to the object’s parent object (project name), and then drop the mouse on the project’s name.
