Question:
How can I display only acknowledged alarms in E3Browser?
Solution:
One way to achieve it is to change the SQL query so as to to filter only the acknowledged alarms. To do so, you must add a Where condition to test whether Acked and ConditionActive fields are equal to 1.
For example (SQL query filtering alarms acknowledged from Alarms table):
SELECT *
FROM Alarms
Where Alarms.Acked=1 And Alarms.ConditionActive=1
ORDER BY Alarms.E3TimeStamp ASC
