KB-16651: Query1(Disconnected) :32 Error Message.
Question:
Why is the message “Query1(Disconnected) :32” being displayed in the legend’s Status column in E3Chart?
Solution:
This happens when there are special characters on a chart’s field, such as spaces, diacritics, or names starting with numbers. We suggest renaming the fields with special characters, or placing their names between brackets.
Print Friendly, PDF & Email
Leave a Reply
