Question:
How can I use the E3Storage?
Solution:
E3Storage is an alternative module for historic data recording. With it, you can transform data from production, processes, other retrievals, and managerial information. This module enables collecting information via OPC servers, Elipse drivers, databases in general, or even with text files and storage in comercial databases (Microsoft SQL Server or Oracle) via user-defined historic objects, in a compact, efficient way.
The data will only be recorded when there is a significant variation (defined by the user), or when an interval is completed with no recordings at all (timeout). Verifications are analyzed by the algorithm BoxCar/BackSlope, which allows up to 93% of data compacting, with total retrieval of really useful information, depending on the defined dead band.
