Question:
How can I use a webcam with E3?
Solution:
There are two possible solutions for this:
- you can use an ActiveX as an interface between E3 and the webcam (register the ActiveX and then insert it onto the screen); or
- you can configure a Frame’s SplitLink property with the webcam’s IP address.
