KB-15510: Changing a pen’s width at runtime.
Question:
How can I change a pen’s width at runtime?
Solution:
To do so, you must change the pen’s Width property via scripts. Example:
Screen.Item(“E3Chart1”).Pens.Item(“Pen1”).Width = 20
NOTE: Attached to this article is a demo application developed with E3 version 3.1 Build 270.
AppPena.zip
Print Friendly, PDF & Email
Leave a Reply
