KB-14984: Text sliding on screen.
Question:
How can I make a text slide on screen?
Solution:
To do so, you must first create a RampUp demo tag on Viewer. Then, on screen, add a display with the following link to Value property:
Right(” text sliding in the display on X screen “, Viewer. demotag.value)
Note: The attached sample application was developed in E3 3.1 Build 270.
AppRunningText.zip
Print Friendly, PDF & Email
Leave a Reply
