KB-14670: Closing the E3Server from the Viewer.
Question:
Can E3Server be closed from the Viewer?
Solution:
No, this cannot be done. The only possibility in this case is, from the computer running E3Server, to click on E3Admin icon (next to the Windows’s clock) and close it manually.
Print Friendly, PDF & Email
Leave a Reply
