Question:
Can I insert Autocad files into E3 applications?
Solution:
E3 does not support the Autocad standard file format (DWG). See the image files supported by E3 in the related article.
Consider the following alternatives:
- Save or convert the design to any supported format by E3;
- Use any available ActiveX control that allow opening the file in its original format.
