KB-13594: Retrieving the RGB value from an absolute value.
Question:
How can I convert an absolute decimal value into its separate RGB values?
Solution:
To do so, you will need to use scripts. In the example below, the script has been added to a button’s Click event:
Dim ColorValue, R, G, B
ColorValue = Screen.Item(“Rectangle1”).ForegroundColor
B = Int(ColorValue / 65536)
G = Int((ColorValue – 65536 * B) / 256)
R = ColorValue – (65536 * B + 256 * G)
MsgBox “R = ” & R & Chr(13) & “G = ” & G & Chr(13) & “B = ” & B
Print Friendly, PDF & Email
Leave a Reply
