KB-13148: Running SCADA and E3 applications in the same computer.
Question:
Can I run both an Elipse SCADA application and an Elipse E3 application in the same computer?
Solution:
Yes, but to do so, both RunTime licenses (SCADA’s and E3’s) must be in the same hardkey. Also, remember to check the communication ports for both applications.
Print Friendly, PDF & Email
Leave a Reply
