Question:
How can I install an HTTPS certificate for Windows Phone?
Solution:
To do so, access the device’s browser and type your domain’s address.
To get the Elipse Mobile application to work properly, you’ll need to register the certificate in the device. To download the certificate, type your domain + /cert in the HTTP connection (in the example, http://thiago.elipse.com.br:8080/cert).
Example:
Select Open to start installing the certificate in the device.
Confirm the server’s address in the certificate and select Install.
If the certificate was configured properly, it will be installed successfully.
Then, access the application and connect to it. To do so, add HTTPS at the server’s URL, instead of HTTP.
