This article shows you how to identify a hardkey’s license number at Elipse E3 and Elipse SCADA.
Identifying the license number at Elipse E3
To do so, follow these procedures:
1. Right-click the E3Admin icon (on Windows’ notification area) and select the option Licenses.
2. On the licenses window, check the field License Number.
Identifying the license number at Elipse SCADA
1. Open Elipse SCADA, select Help option, and then click About Elipse SCADA.
2. Alternatively, you can also press Ctrl+Shift+V when Elipse SCADA is open or when an application is being executed.
3. On the information window, check the field License #.
