How to alter a color by its value in Section Report.
Question:
How can I alter the color on a line when printing a  Section Report of Elipse E3 according to the value in the field?
Solution:
To do so, use the Section Report’s  Detail_Format event, via a script that checks the value of the field’s Text property do campo and alters its ForeColor property accordingly.
Example:
Sub Detail_Format
If Val(Me.Field5.Text) >= 70 Then
Me.Field5.ForeColor = System.Drawing.Color.Red
ElseIf Val(Me.Field5.Text) < 30 Then
Me.Field5.ForeColor = System.Drawing.Color.Blue
Else
Me.Field5.ForeColor = System.Drawing.Color.Black
End If
ChangeFieldColorOnFormat1.zip
NOTE: The attached application was developed with Elipse E3 v. 6.6.292.
Print Friendly, PDF & Email
Leave a Reply
