The HistTool library is a very simple tool, perfect for quick viewings and small operations on Historics. It was developed to be auto-configurable, thus avoiding time waste when setting up the browser and queries.
With this library, you will be able to:
- Hide or show the Quality fields.
- Insert and delete records.
- Reconfigure the historic’s scan time.
- Query using a date/time filter.
- Export the table to an Excel file.
To use this feature, follow these guidelines:
- Extract the attached file to your computer (preferablyin the application folder).
- In E3Studio, add the library to your domain.
- Insert an XcHistTool object onto screen.
- Select the Historic on the XcHistTool object’s HistSource property.
Important: to use this tool, there must be a historic already configured in the application.
The attached demo library was developed with Elipse E3 v3.2 b260.
