Question:
How can I display values in milliseconds in a Section Report of Elipse E3?
Solution:
To display date/time values in milliseconds, you’ll need to edit the format at SQL syntax Section Report‘s.
Example (SQL Server):
SELECT Format([E3TimeStamp] , 'yyyy-MM-dd HH:mm:ss.fff') as DataHoraMS, Campo1, Campo2 FROM [Tabela1] ORDER BY DataHoraMS ASC
Example (PostgreSQL):
SELECT to_char(pgsql.E3TimeStamp, 'DD-MM-YYYY HH24:MI:SS.MS'), pgsql.Campo1 FROM pgsql ORDER BY pgsql.E3TimeStamp ASC
