Question:
How can I remove the Quality column from a Historic?
Solution:
To remove the Quality column from a Historic, you must use the Link Historic to an existing Table option. To do so, there are two possibilities:
1. Create manually a table in the Database with the desired fields and use the option that links them to an existing table in the Historic; or
2. Create a table in the Database via a Historic object, access it from inside the Database and click the Edit option. Remove the Quality fields, access the Historic object again and reset it with the option to link it to the existing table.
