Question:
Which version of Siemens Prodave driver must be used with each version of Siemens Prodave MPI software?
Solution:
For Siemens Prodave MPI v5.6 or lower, you must use:
- Siemens Prodave driver v1.01
- Windows XP or lower
For Siemens Prodave MPI/IE v6.0, you must use:
- Siemens Prodave driver v2.0.1
- Windows 2000 or Windows XP
For Siemens Prodave MPI/IE v6.1, you must use:
- Windows XP or Windows Vista
For Siemens Prodave MPI/IE v6.2, you must use:
- Windows XP, Windows Vista, or Windows 7
NOTE: The complete, updated table of Windows compatibility with Prodave software can be checked directly at Simens’ support site.
