Description:
The Micrologix 1100 has an embedded ethernet port that can be used to comunicate with ABDF1 driver. To do so, the driver must usually be set up as follows:
PLC Type = “Micrologix 1100”
Transport = “ENIP”
However, in certain cases you must change the field PLC Type to “Micrologix 1500”, due to the device’s firmware version.
