Question:
Can Rockwell’s Micrologix 1400 PLC communicate via ABDF1 driver? How should it be set up?
Solution:
Yes, it can. To do so, access the driver’s settings, Rockwell AB DF1 tab, and set up PLC Type as SLC500 and Transport as ENIP.
In addition to these settings, you must also access Ethernet tab and set Port property as 44818.
also provide tags N1,N2,N3,N4 parameters settings, how to read tags?
Hello Shrikant,
The driver manual has the “[N] Parameters for Addressing PLC-Type Tags” chapter.
You can download this manual with the ABDF1 driver in the link below.
https://www.elipse.com.br/en/downloads/?key=abdf1&language=enus
