Question:
How can a Section Report in Elipse E3 display the minimum, maximum, and average values of a field that is stored in a Historic?
Solution:
To do so, follow these procedures:
- Set the section report’s query to retrieve the desired field. For example: SELECT Current.Historic FROM Historic
- Create three Data Fields in the section report with the following settings:
– Field Minimum:
SummaryFunc = 3 – rv2Min
SummaryRunning = 0 – rv2NoSR
SummaryType = 1 – rv2GrandTotal
– Field Maximum:
SummaryFunc = 4 – rv2Max
– Field Average:
SummaryFunc = 1 – rv2Avg
Set these object’s DataField properties with the name of the desired field, exactly as they appear in the SQL query.
