BUG-0010260: Alarm message remains in the summary if AlarmSource is disabled in E3 Studio.
OVERVIEW
Alarm messages can remain active in the summary if its corresponding AlarmSource is disabled via Studio, and then the domain is restarted.
HOW CAN I REPRODUCE THIS PROBLEM?
  • Stop domain execution with an active alarm
  • Deactivate alarm verification via Studio, and set AlarmSource’s AlarmVerify property as False
  • Run the Domain
This problem will not happen if the Domain is only updated, and not restarted.
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download can be found here.
THIS ARTICLE APPLIES TO THESE PRODUCTS
Elipse E3 version 1.00.0021 Build 96 or higher
Elipse E3 version 2.0
Elipse E3 version 2.5
Elipse E3 version 3.0
Elipse E3 version 3.1
Print Friendly, PDF & Email
Leave a Reply
