OVERVIEW
E3Server closes when Windows returns from Hibernate or Standby statuses.
HOW CAN I REPRODUCE THIS PROBLEM?
- Let the system hibernate for over 5 minutes
- When you reactivate the system, E3 Admin’s status is “Not Connected”, and a message is displayed saying “Trying to connect to E3 Server”
WORKAROUND
To get around this problem without having to install the software’s new version, you must finish E3 Server’s task by using Windows Task Manager every time E3 closes.
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download can be found here. .
IMPORTANT: In spite of this correction, E3 does not support Windows’ Standby or Hibernate modes when the domain is running.
THIS ARTICLE APPLIES TO THESE PRODUCTS:
Elipse E3 version 3.0
Elipse E3 version 3.1 (build 195 or lower)
