OVERVIEW
When the HOT server’s network cable is unplugged, the time of switchover between hot-standby servers is always higher than 20 seconds, regardless of how long this time has been set in the domain’s “switchover time” option.
HOW CAN I REPRODUCE THIS PROBLEM?
- Execute a HotStandby domain
- Unplug the network cable from the active (HOT) server
- After 20 seconds, the Standby machine will execute the domain
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download for version 3.0 can be found here.THIS ARTICLE APPLIES TO THESE PRODUCTS:
Elipse E3 version 3.0 (build 432 or lower)
Elipse E3 version 3.1 (build 139 or lower)
