OVERVIEW
When you link an E2Button to a tag, this object’s status (pressed or not) is not updated according to tag value, even when correctly configured. E2Button will only work if clicked on once.
HOW CAN I REPRODUCE THIS PROBLEM?
- Create an internal tag, and change Value property type to integer.
- Create a screen with an E2Button and a setpoint.
- Link the button’s and the setpoint’s Value properties to the internal tag.
- Run the application, and then change setpoint value from 0 to 1. Notice that the button’s status remains the same.
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download can be found here.
THIS ARTICLE APPLIES TO THESE PRODUCTS
Elipse E3 version 3.0
