OVERVIEW
If the AlarmServer is deactivated and then reactivated in runtime, the alarms summary becomes empty and is no longer updated.
HOW CAN I REPRODUCE THIS PROBLEM?
- Start up a domain;
- Activate a few alarms;
- Deactivate AlarmServer with Deactivate method;
- Reactivate AlarmServer with Activate method;
- Activate a few alarms.
WORKAROUND
You can get around this problem by deactivating and then reactivating all AlarmSource objects in the application.
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download can be found here.
THIS ARTICLE APPLIES TO THESE PRODUCTS
Elipse E3 version 2.0 or lower
Elipse E3 version 2.5
Elipse E3 version 3.0
Elipse E3 version 3.1
