OVERVIEW
If an alarm area’s name is changed at runtime, its old name will still be displayed in the alarm’s fields (Area, FullAlarmSourceName).
HOW CAN I REPRODUCE THIS PROBLEM?
- Change an area’s name in runtime, either via scripts or via links.
WORKAROUND
After the area’s name has been altered, you can get around this problem by deactivating and then reactivating all AlarmSource objects inside this area.
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download can be found here.
THIS ARTICLE APPLIES TO THESE PRODUCTS
Elipse E3 version 2.0 Build 242 or higher
Elipse E3 version 2.5
Elipse E3 version 3.0
Elipse E3 version 3.1
