We recommend that all clients using Elipse E3 v. 3.2 b. 217 to 259, communicating with either an Access or SQLServer database, upgrade it to E3 v3.2 Build 260. This is due to a bug (now fixed) verified in the connection between the software and these databases.
This bug caused valid connections to the databases to be discarded, which generated an excessive consumption of resources. In addition, there were issues in the Formula’s SaveFormulaValues and SetValueData methods, which could cause possible GPFs in E3Run’s process.
