This article will help you activate log sections in Elipse E3. Some log sections are only activated on demand. The following procedures show you how to do it.
Activating logs per sections
Logs sections activation and deactivation happen via E3 Tweak, a program installed alongside Elipse E3. Inside this program, you will see displayed options such as recording time and section modules to be recorded; click the desired option to set it to Yes.
Specific sections can be activated at Elipse Software’s discretion; they can also be activated on demand, if a user wants to obtain more detailed information about the application.
Upon activation, the logs are created in a folder specified by the log system. When deactivating a section, the file stops being generated/updated.
