Accessing E3 Sample Application.
Description:
After installing E3, you can execute a sample application that demonstrates several available features of the software.
To open the application, you must access the Start menu >> Programs >> Elipse Software >> Elipse E3 >> Sample Application option.
This application can be executed on DEMO mode, so you do not need a hardkey.
Print Friendly, PDF & Email
Leave a Reply
