Question:
How can I access all tags of a Driver if it has several subfolders?
Solution:
To do so, you must write a script using recursion.
Example (script executed at a button’s Click event):
Sub CommandButton1_Click()
set Driver = Application.GetObject(“DriverModbus”)
FuncRecursion(Driver)
Sub FuncRecursion(folder)
for each obj in folder
if typename(obj) = “IOFolder” then
FuncRecursion(obj)
else
msgbox obj.Name
end if
next
