Demo application: Information exchange via remote applications.
Allows the connection and the information exchange between two applications.
The attached file contains two applications: the server (which must run first), and the client. These application use Mirror network driver, which works via files, but they can easily be modified to use TCP/IP, Modem, or serial cable communication.
For an example of application using TCP/IP driver, check KB-28384: Remote applications in Elipse SCADA.
ex_appremo
