Elipse E3 versions license.
How does Elipse E3 handle its version licenses?
Elipse E3 licensing is handled safely via a USB device (hardkey) or a software device (softkey). These devices control de software versions being employed in each case, ensuring the most proper version for each environment is always used, and allowing clients with obsolete versions to upgrade to more current ones.
To install Elipse E3 properly, you need to make sure the version being used is compatible with your license, otherwise the software will only open in Demo mode. If you are unsure of which version you have acquired, contact Elipse Software’s technical support and provide your license number.
To download different versions of Elipse E3, visit our website.
To compare versions’ features, check out Elipse E3’s Release Notes.
NOTES:
  • E3 Studio licenses have no version control.
  • E3 Master licenses have version control.
  • Subscribers to Elipse Care are entitled to upgrade their licenses’ version. For more information, contact our sales department.
