KB-81331: Stopping/Starting Windows services via Elipse E3 scripts.
Can Windows services be stopped/started via Elipse E3 scripts?
Yes, they can. To do so, insert the script bellow into the Click event of a button interacting with the SQL Server database:
set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\.\root\cimv2")
set colServiceList = objWMIService.ExecQuery("Select * from Win32_Service where Name = 'MSSQL$SQLEXPRESS'")
for each objService in colServiceList
if objService.state = "Running" then
objService.StopService() 'stop service
else
objService.StartService() 'start service
end if
next
This script uses (Windows Management Instrumentation) objects. For further information about these objects, check this article.
