Question
The tag’s timestamp information are available in discrete strings (one field for date, one for hour, and so on). How can IÂ convert this timestamp into DateTime value, with a milliseconds precision, and use this resulting timestamp elsewhere?
Solution
To do so, create a script similar to the one below. Remember that VBScript’s CDate command has no milliseconds precision, so you will need to convert the milliseconds separately and then add this value to the previous one.
To visualize a DateTime variable with milliseconds precision in a display, it will have to be formatted as: “dd/MM/yyyy HH:mm:ss.000”
