KB-26943: Viewing images from closed-circuit television (CCTV) in Elipse SCADA.
How can I view images from closed-circuit television (CCTV) in Elipse SCADA?
To do so, you must use the Watcher module with one of the options below:
  • Sensoray 611 or 613 cards;
  • Integral Tech Xpress Plus card;
  • any other system using Video for Windows.
