KB-61516: Start E3 Server option is blocked.
In Windows XP, why does the option Start E3 Server appears to be blocked on the E3 Admin tool bar after E3 Server has stopped?
This happens because the user is not allowed to start this process, which is something that normally happens to limited users (that is, those who do not have administrator privileges).
NOTE: This does not happen in Windows 7 because it uses UAC (User Account Control) settings and then will call an administrator’s log-in page to run the process.
