KB-28435: Activating a digital alarm according to values in two tags.
How can a digital alarm be set up to be activated when the values of two different tags are both TRUE?
To do so, just write an AND command between both tags’ values at the digital alarm’s source.
Example: Driver1.Digital01.Value AND Driver1.Digital02.Value
