KB-36306: Updating a historic graph.
Why are the data in a historic graph not being loaded?
To make sure Trend object displays the data from a Historic, you must create a script that executes the Trend’s LoadHistoricData() function.
Example: Trend1.LoadHistoricData()
NOTE: Attached to this article is a demo application developed with Elipse SCADA v. 2.29.
Trend.zip
