KB-43882: Write via DNP driver working on Studio mode, but not via Setpoints on screen.
Why does DNP Driver 3.0 only write when in Studio mode, but it does not receive the values written on (and accepted by) the Setpoints?
This happens because the default value format to be sent by setpoints is text, but the driver expects a number; thus, the value used is 0.  This can be fixed either by configuring the setpoint as a numeric type or via CLng function; to do so, just add the script below to the setpoint’s Validate event.
Value = CLng(NewValue)
