Mouse position at E3 Playback.
At E3 Playback, can I change the mouse’s previous position?
Yes. I has become possible since E3 version 3.5, thanks to two new Viewer’s methods:  GetMouseX() and GetMouseY(). To do so, this information must be stored in the database.
Note: Attached to this file is a sample application.
ID4278
