When I insert an ActiveX onto screen, an error 80040112 is displayed. What does this mean?
This error indicates the ActiveX being inserted is not licensed in your PC. During instancing, the control searches the register for its license key (HKEY_CLASSES_ROOT\Licenses) and, if it does not find it, it returns this error. There are license keys for Active X objects for both development and runtime environments.
To fix this problem, you must purchase this ActiveX’s license and register it to your PC.
