KB-31076: Script for scanning files in a directory.
How can I scan a directory to search files?
To do so, you must use FindFirstFile and FindNextFile functions.
NOTE: Attached to this article is a sample application developed with Elipse SCADA version 2.29 build 092.
FileFiltering.zip
