KB-28155: Communicating with Siemens S7 PLCs.
Which driver can I use to communicate with S7-200/S7-300/S7-400/S7-1200 PLCs?
Elipse Software has developed several I/O drivers for Siemens devices, and the most widely used with S7 series is M-Prot driver. This driver can communicate with several protocols, and the PLC must be set up accordingly. Below there is a reference table for M-Prot protocols.
Elipse Driver Siemens M-PROT: Quick reference
CLP
Hardware Siemens
Interface
Selected protocol
S7-200
PPI/PC Adapter
Serial
PPI
CP-243
Ethernet
“ISOTCP243” (ISO-TCP)
S7-300
MPI/PC Adapter
Serial
MPI
CP-3XX
Ethernet
ISO-TCP
S7-400
MPI/PC Adapter
Serial
MPI
CP-433
Ethernet
ISO-TCP
CP-443
ISO-TCP
S7-1200
Ethernet
ISO-TCP
NOTES:
  • Adapters via USB interface (Siemens PPI-MPI/PC cable) are not supported by M-Prot driver.
  • Different combinations can eventually be contemplated. The ones presented in this article are the most common ones, though.
  • They can also be linked with hardware that is not produces by Siemens. M-Prot’s help presents a few possibilities. However, the user must research the subject before associating with unknown hardware.
  • ISO-TCP protocol can also be called ISO over TCP, RFC1006, or S7-TCP/IP.
Classificação média - Average rating 1 / 5. Count: 1
