KB-27605: Executing Windows calculator via application.
How can I call the Windows calculator at run time?
To do so, you must use the Global Manager’s ShellExecute method:
ShellExecute (strOperação, strArquivo, strParametros, strDir, nCmdVisual))
Example of script:
ShellExecute(“open”,”calc”,””,””)
