KB-27284: Starting a SetPoint with the current time/date.
How can I configure a SetPoint to be opened with the current time?
To do so, you must create a script in the setpoint’s OnStartRunning event, and attribute to its Value property the metod Now (VBScript), which returns the current date/time.
Example:
Sub Text1_OnStartRunning()
    Value = Now
