KB-29583: Using E3Studio in DEMO mode.
What are the restrictions when using E3Studio in DEMO mode?
In DEMO mode, you cannot save projects with more than 20 I/O Tags. Other restrictions are:
  • It is not possible to work with Hot-Standby.
  • It is not possible to work with Remote Domains.
  • In Runtime mode, communication is allowed with one single driver level 0 and limitless tags (In Studio mode no restrictions) .
  • You cannot access the Domain settings (E3Admin menu, Domain–Options).
  • Only the first image of each category of the Symbols Gallery is available.
  • Projects with more than 20 tags will not be saved.
  • You will be able to open only 1 Viewer (or WebViewer).
  • You can execute the Domain for up to 2 hours.
