KB-32374: Changing the color of an E3 Gallery’s figure.
Can I change the color of an E3 Gallery’s figure?
Yes. To do so, insert the desired image onto a screen, and then follow this procedure:
  1. On the figure’s property list, configure the OverrideFillMode property to 2 – solid or 3 – ByBrightness.
After that, you can change its color with OverrideFillColor property.
Este artigo foi Ăştil? Was this helpful?
