KB-27430: MsgBox and Display objects showing different values.
Why do the MsgBox and the Display objects show the same value of a variable, but in different languages?
This happens because the MsgBox object uses the Visual Basic standard and returns the message in the language set on Windows, and the Display object always shows it in English.
